Выберете то, что вам нужно
Place the TV face down on a flat smooth surface as to not scratch the screen.
Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
Remove the green and gray power connector from the side of the buttons panel at the top of the television.
Remove the green/gray to orange/gray connector from the center of the circuit board.
Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
Remove the three 5mm Philips screws attaching the circuit board to the LCD.
Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD.
Turn the television so the right hand side is facing you.
Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
Turn the circuit board so that the left side is facing you.
Detach the data cable from the circuit board.
To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
2 участников успешно повторили данное руководство.
