Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will help you disassemble your Sharp Aquos LC13B2UA and replace the speakers. If your speakers are no longer working, then this guide can show you how to replace them.
Запчасти
Детали не указаны.
  1. Place the TV face down on a flat smooth surface as to not scratch the screen. Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Lift the stand off the television. Lift the stand off the television.
    • Lift the stand off the television.
  3. Remove the two back panels by prying them out with your hands. Remove the two back panels by prying them out with your hands. Remove the two back panels by prying them out with your hands.
    • Remove the two back panels by prying them out with your hands.
  4. Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge. Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Using your hands, gently lift and remove the back case of the television.
    • Using your hands, gently lift and remove the back case of the television.
  6. Remove the eight 9mm screws from both speakers. Do not remove the speakers yet—they are still attached.
    • Remove the eight 9mm screws from both speakers.
    • Do not remove the speakers yet—they are still attached.
  7. Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
    • Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  8. Remove the two black tape strips (one on each side) securing the power cable to the frame. The speakers can now be removed.
    • Remove the two black tape strips (one on each side) securing the power cable to the frame.
    • The speakers can now be removed.
Заключение
Robert Hobson
Участник с: 20.01.2011
1 275 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 1-11, Amido Winter 2011 Участник Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 4,404
