Введение
This guide will help you take off the back of the phone and look for any issues within the phone. After completing this disassembly and the problem is determined then you may want to take a look at some of the other repair guides in order to fix the issue whether it be the battery or the speaker.
Выберете то, что вам нужно
Remove case around battery using a T5 screwdriver to remove four 5mm silver screws.
Remove two 6mm T5 black screws.
Use the tweezers to remove the pink clips on either side of the device and then take the casing off.
