Sharp EL-520X Loose Circuit Board Wire Fix
Выберете то, что вам нужно
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: шаг 1, изображение 1 из 1
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: шаг 2, изображение 1 из 2 Sharp EL-520X Loose Circuit Board Wire Fix: шаг 2, изображение 2 из 2
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: шаг 3, изображение 1 из 1
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: шаг 4, изображение 1 из 1
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: шаг 5, изображение 1 из 1
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: шаг 6, изображение 1 из 1
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: шаг 7, изображение 1 из 3 Sharp EL-520X Loose Circuit Board Wire Fix: шаг 7, изображение 2 из 3 Sharp EL-520X Loose Circuit Board Wire Fix: шаг 7, изображение 3 из 3
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
Финишная черта
2 участников успешно повторили данное руководство.
Mohamad Mohamad
Участник с: 01/18/21
436 Репутация
Автор 3 руководств
Команда
York University, Team M-6, Allen Summer 2023 Участник York University, Team M-6, Allen Summer 2023
YORK-ALLEN-SU23SMG6
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 18
За последние 30 дней: 37
За всё время: 292
