Введение
Speakers rely on precisely placed components to convert electronic signals into sound waves. Touching the speaker by pushing or pulling can cause the speaker components to deform. As a result, the speaker will no longer produce an accurate sound. Replacing the speaker is the best repair for speaker damage.
Выберете то, что вам нужно
Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
