Введение
Prerequisite Only
Выберете то, что вам нужно
Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
Locate the bottom of the device.
Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
Use the plastic opening tool to pry open the plastic panel from the top of the camera.
Locate the two screws on the top of the device.
Еще один человек закончил это руководство.
