Введение
The user will learn how to:
- Remove the device from the case
- Completely tear down the device
- Remove the lens
Выберете то, что вам нужно
Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
Locate the bottom of the device.
Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
Use the plastic opening tool to pry open the plastic panel from the top of the camera.
Locate the two screws on the top of the device.
Behind the lens, use the metal screwdriver to unscrew the two screws holding the lens in place on the circuit board.
Еще один человек закончил это руководство.
