Введение
The user will learn how to:
- Remove the device from the case
- Locate the memory card
- Remove memory card
- Insert memory card
Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
To remove the micro SD card from the device, gently push the SD card and release. The SD card will pop out.
When putting a micro SD card back into the device, be sure to place the exposed metal side up, as well as have the device LCD screen side up.
2 человек успешно провели ремонт по этому руководству.
