Sharper Image iPulse SI325 Outer Case Replacement
Выберете то, что вам нужно
  1. Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: шаг 1, изображение 1 из 2 Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: шаг 1, изображение 2 из 2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 Outer Case Replacement: шаг 2, изображение 1 из 3 Sharper Image iPulse SI325 Outer Case Replacement: шаг 2, изображение 2 из 3 Sharper Image iPulse SI325 Outer Case Replacement: шаг 2, изображение 3 из 3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 Outer Case Replacement: шаг 3, изображение 1 из 2 Sharper Image iPulse SI325 Outer Case Replacement: шаг 3, изображение 2 из 2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
Заключение
Melissa Pasa
Участник с: 10/13/13
701 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 11-33, Amido Fall 2013 Участник Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 335
