Введение
This guide will teach you how to clean your fan and replace the silicone grease in your Shenzhou k680e laptop. Too much dust in the fan of your laptop will seriously weaken the heat radiation of your computer. It will make your computer work slowly and can lead to a crash which would cost you a lot of time. In addition, silicone grease on the chips plays an important role on heat radiation, so it’s important to replace it after a long time.
Выберете то, что вам нужно
Place the computer on a table so that its bottom surface is facing you.
Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
Еще один человек закончил это руководство.
