Введение
This guide will walk you through the process of replacing the filter cage on the MC150A Shop-Vac.
Выберете то, что вам нужно
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Slide the foam sleeve up from the filter cage to remove it.
Use a 3.5 mm hex key to remove the two screws securing the filter cage.
Почти готово!
Заключение
