Введение
This guide will teach you how to remove and replace the motor for the MC150A Shop-Vac.
Выберете то, что вам нужно
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
Pull out and disconnect the four spade connectors from the switch module.
Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
During reassembly, be sure to reattach the green ground wire clip to the bracket.
Turn the part over to the other side.
Use the socket wrench remove the bolt securing the aluminum plate.
Unscrew the two Phillips head screws holding the cover to the motor.
After removing the cover to the motor, you can replace the motor.
6 участников успешно повторили данное руководство.
2 Комментариев
Where do I buy a new motor?????
Yeah that's what we all would like to know, removing is the easy part
