Введение
This guide explains how to help you as a user fix the wheels on your glass sliding shower door. This is a step by step process accompanied by photos to help show the process. Since the door is glass, make sure to be extra careful when moving the doors around and when replacing them.
Before starting your fix, make sure to clean out your shower and pick a designated spot to carefully place the doors.
Выберете то, что вам нужно
Locate the top metal cover.
Unlatch the wheels by pushing the door away and up from you to bring the wheels out of the track.
Once the wheels have been unlatched from the track, push the metal cover all the way up and set aside.
Remove the wheels from the door by taking the Phillips #2 screwdriver and unscrew the screw until you are able to remove the wheel.
Take a wet rag and clean off any built up gunk off the bracket.
Clean the track as well, to help the door slide better.
To replace the new wheels, take the Phillips #2 screwdriver and screw the wheels back into place on the bracket with the 7mm screws.
Once the new wheels are attached, manually spin them to make sure they spin properly.
To place the top metal cover back on, make sure the front door has the wheels facing towards you and the inside door has the wheels facing opposite of you, the wheel bearing will be facing you.
I hope this guide was helpful for your fast fix. Enjoy your newly improved shower door!
