Введение
If you have a shower head with a constant drip, follow this simple and easy guide to replace the rubber o-ring in your shower handle. Replacing the O-ring can help prevent hard water build up, rusting, and wasting water.
Выберете то, что вам нужно
Using your flat head screwdriver, remove the screw from the middle of the handle.
Use your groove joint pliers to loosen and remove the escutcheon plate.
Using your groove joint pliers, loosen and remove the cartridge stem.
Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
3 участников успешно повторили данное руководство.
2 Комментариев
I have to change my shower handle, but the plumber asking me to change the shower valve also. But I can’t see any reason to replace the shower valve, is it really necessary to change it when changing shower handle.
Thanks.
