Введение
For this repair you will learn how to replace a battery, one topic that will need to be understood is how to use a soldering iron. Being able to use that will have a big effect on replacing the battery.
Выберете то, что вам нужно
Remove the suction pad by pulling the suction out of the slot that it is in.
Remove the four 9.09mm Philips #1 screws that hold the 2 pieces of the cover together.
Pull apart the two halves.
Remove the four 5mm Phillips #1 screws from the motherboard.
Desolder the two wires connecting the battery tp the motherboard.
