Введение
The faceplate connects all of the internal wiring of the microphone. If it is defective (or wires need to be reattached to it), this guide shows how to replace it.
Инструменты
Запчасти
Детали не указаны.
Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
Почти готово!
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
Заключение
