Введение
The faceplate connects all of the internal wiring of the microphone. If it is defective (or wires need to be reattached to it), this guide shows how to replace it.
Выберете то, что вам нужно
Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
Why should I replace the plate?
Gerrit - Ответить
This guide was done as part of the capsule replacement—I don’t think there is any reason to solely replace the plate unless there was corrosion on it.
Daniel Berger - Ответить
