Shure SM58 XLR Connector Replacement
Выберете то, что вам нужно
  1. Shure SM58 XLR Connector Replacement, Connector: шаг 1, изображение 1 из 3 Shure SM58 XLR Connector Replacement, Connector: шаг 1, изображение 2 из 3 Shure SM58 XLR Connector Replacement, Connector: шаг 1, изображение 3 из 3
    • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
    • Make sure you are not holding the microphone connector by the wires.
    • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
  2. Shure SM58 XLR Connector Replacement: шаг 2, изображение 1 из 2 Shure SM58 XLR Connector Replacement: шаг 2, изображение 2 из 2
    • Hold the microphone connector in one hand and the microphone base in the other.
    • Line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  3. Shure SM58 XLR Connector Replacement: шаг 3, изображение 1 из 2 Shure SM58 XLR Connector Replacement: шаг 3, изображение 2 из 2
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  4. Shure SM58 XLR Connector Replacement: шаг 4, изображение 1 из 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
    Hi looks simple but I can't undo screw turns so far and locks up. Can you help. Kind regards.
    Tony White - Ответить
    Are you trying to disassemble or reassemble the microphone?
    Daniel Berger - Ответить
    In my case, i try to disassemble.. But it wont come off. Anticlockwise the screw… infinite turns… TheThe connector is not stuck, it wabbe a bit, but the screw maybe wont recess enough.
    nunoandrade - Ответить
    How do I replace the screw? Lost it, and need to replace it.
    Katrina - Ответить
Заключение
Following these steps should reinstall the XLR connector back into the microphone.
2 участников успешно повторили данное руководство.
nat coll
Участник с: 09/27/12
642 Репутация
Автор 14 руководств
Команда
Cal Poly, Team 7-53, Forte Fall 2012 Участник Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 членов
Автор 20 руководств
2 Комментариев
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 70
За всё время: 17,275
