Shure SM58 XLR Microphone Connector Installation Replacement
Выберете то, что вам нужно
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: шаг 1, изображение 1 из 1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: шаг 2, изображение 1 из 1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: шаг 3, изображение 1 из 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Заключение
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 участников успешно повторили данное руководство.
Ronald Lam
Участник с: 09/27/12
307 Репутация
1 руководство автора
Команда
Cal Poly, Team 7-53, Forte Fall 2012 Участник Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 членов
Автор 20 руководств
7 Комментариев
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - Ответить
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - Ответить
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - Ответить
Are the threads on your screw stripped?
Daniel Berger - Ответить
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 24
За всё время: 10,526
