Введение
Taking out the thumbwheel.
Запчасти
Никакие детали не требуются.
  1. Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
    • Remove 2 screws using the Torx 6 screwdriver.
    • The thumbwheel and casing will be loose, gently remove it.
Финишная черта
michael albaum
Участник с: 20.01.2010
45 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-19, Maness Winter 2010 Member of Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 членов
Автор 11 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 2,050
