Siemens EQ5 ceramic valve overhaul
Выберете то, что вам нужно
  1. Siemens EQ5 ceramic valve overhaul, Remove Siemens EQ Series side panel (tank side).: шаг 1, изображение 1 из 1
    • Never forget: pull out the mains plug!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Remove the coffee container lid and take out all the coffee beans.
  2. Siemens EQ5 ceramic valve overhaul: шаг 2, изображение 1 из 1
    • Unscrew the two Torx T10 screws at the top of the right side panel.
    • Some models do not have these screws. Then the side parts are only held by catches, some of which clamp very strongly. You may have to detach the back part first.
  3. Siemens EQ5 ceramic valve overhaul: шаг 3, изображение 1 из 3 Siemens EQ5 ceramic valve overhaul: шаг 3, изображение 2 из 3 Siemens EQ5 ceramic valve overhaul: шаг 3, изображение 3 из 3
    • Lay the machine on its side with the water tank side facing up.
    • The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
    • If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
    • Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
  4. Siemens EQ5 ceramic valve overhaul: шаг 4, изображение 1 из 1
    • You may need to pry the front edge with a plastic tool.
    • Lift the side panel off, but don't remove it completely yet. It is still connected with a silicone tube.
    • The water tank lid is located at the top of the side panel. Lift it up off the hinges.
  5. Siemens EQ5 ceramic valve overhaul: шаг 5, изображение 1 из 1
    • Pull off the silicone hose that leads to the water connection of the tank from the inside.
  6. Siemens EQ5 ceramic valve overhaul: шаг 6, изображение 1 из 2 Siemens EQ5 ceramic valve overhaul: шаг 6, изображение 2 из 2
    • Remove the cover over the electronics.
    • The second picture shows the most important components:
    • heater
    • Ceramic valve/Brew valve (depending on model)
    • electronics
    • pump
    • mute
    • flow meter
  7. Siemens EQ5 ceramic valve overhaul, EQ 5 ceramic valve: шаг 7, изображение 1 из 3 Siemens EQ5 ceramic valve overhaul, EQ 5 ceramic valve: шаг 7, изображение 2 из 3 Siemens EQ5 ceramic valve overhaul, EQ 5 ceramic valve: шаг 7, изображение 3 из 3
    • If you haven't already done so: Remove the two plastic covers over the cables and the electronics box.
  8. Siemens EQ5 ceramic valve overhaul: шаг 8, изображение 1 из 3 Siemens EQ5 ceramic valve overhaul: шаг 8, изображение 2 из 3 Siemens EQ5 ceramic valve overhaul: шаг 8, изображение 3 из 3
    • Locate the two strands of wire going from the ceramic valve to the motherboard. Unplug the connectors and unthread the cables.
  9. Siemens EQ5 ceramic valve overhaul: шаг 9, изображение 1 из 1
    • Turn the machine over. Remove the three Torx T15 screws securing the ceramic valve. Pay attention to the washers.
  10. Siemens EQ5 ceramic valve overhaul: шаг 10, изображение 1 из 1
    • Turn the machine over again.
    • Pull out the clamp on the pressure hose to the ceramic valve.
    • Pull off the pressure hose and push it aside.
  11. Siemens EQ5 ceramic valve overhaul: шаг 11, изображение 1 из 2 Siemens EQ5 ceramic valve overhaul: шаг 11, изображение 2 из 2
    • Carefully pull out the valve.
    • Pull off the thick and thin silicone hoses.
  12. Siemens EQ5 ceramic valve overhaul: шаг 12, изображение 1 из 2 Siemens EQ5 ceramic valve overhaul: шаг 12, изображение 2 из 2
    • Pull off the clamps on the other two pressure hoses. Make a note of which hose goes where and detach the two hoses.
  13. Siemens EQ5 ceramic valve overhaul: шаг 13, изображение 1 из 1
    • Remove the ceramic valve.
  14. Siemens EQ5 ceramic valve overhaul, Revise EQ5 ceramic valve: шаг 14, изображение 1 из 1
    • Unscrew the four Torx T20 screws holding the ceramic valve together.
  15. Siemens EQ5 ceramic valve overhaul: шаг 15, изображение 1 из 3 Siemens EQ5 ceramic valve overhaul: шаг 15, изображение 2 из 3 Siemens EQ5 ceramic valve overhaul: шаг 15, изображение 3 из 3
    • Carefully disassemble the valve into two parts.
    • Take out the ceramic discs very carefully. If they fall, they may break!
    • Slide the slices apart. Clean and descale them.
    • The discs can only be reinstalled in one way. Pay attention to the narrow and wide grooves. The smooth sides must face the larger and moveable middle disk.
    • Carefully detach and clean the two black rubber seals. Note how they are installed.
    • Blow into all canals and check that they are clear.
    • If the valve does not find a position, one or both microswitches are defective. Then you have to exchange them. These are easily available standard types from SAIA, the type designation is printed on them.
Заключение
Follow the steps in reverse order to reassemble your device.
Особая благодарность этим переводчикам:
de en
100%
oldturkey03помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
VauWeh
Участник с: 10/19/15
203 382 Репутация
Автор 246 руководств
Команда
Repair is War on Entropy Участник Repair is War on Entropy
Community
25 членов
Автор 1 121 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 40
За последние 30 дней: 206
За всё время: 6,482
