Введение
If the coffee only sprays weakly out of the two outlets, or only pours out of one of the two outlets, then they are probably clogged with coffee fat. It's difficult to properly clean the component as the aroma of the coffee will always suffer. The replacement part costs less than 4 euros, the replacement is pretty easy and will be described here. Unfortunately, in contrast to the Surpresso Compact, the housing has to be opened.
Note: the opening of the device is shown on a Surpresso Compact, but it is basically the same. Pay attention to any cables to the sensors.
Выберете то, что вам нужно
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
The semicircular decorative strip around the panel above the coffee spout is held from the inside on the left and right by two small white plastic wedges. Use your fingers to pull them out.
Insert a plastic opening tool into the gap on the side and separate the two halves of the case. The clips are pretty tight.
Remove the two Torx T10 screws on the coffee spout distributor.
Disconnect the silicone tube at the top of the coffee spout distributor. Pay attention to the wire spiral.
Remove the coffee spout distributor.
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
100%
VauWehпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
