Siemens-Maquet Servo-i Battery Module Replacement
Медицинское оборудование
Ни iFixit, ни данное руководство по ремонту не одобрены и не связаны с производителем медицинского оборудования.
Выберете то, что вам нужно
    • Check the battery date. The battery needs replacing after 3 years.
    • The manufacturing date is listed in the format (year-week) on the battery label.
    • Servo-i User Manual page 19.
    • If battery status on touchpad display is red make sure to replace battery modules.
    • At least one battery module must be installed at all times. If not the ventilator will not work properly.
    • Store uninstalled batteries at 15-20 degrees celsius.
  1. Siemens-Maquet Servo-i Battery Module Replacement: шаг 3, изображение 1 из 1
    • Wait for the battery to be fully charged.
    • To check this, press the battery power symbol button on the battery.
    • All four LED's must be lit.
    • Servo-i User Manual page 20.
  2. Siemens-Maquet Servo-i Battery Module Replacement: шаг 4, изображение 1 из 1
    • With gas, patient tubes and test lung connected, let the Servo-i run in a ventilation mode.
    • Disconnect mains power to the unit to allow battery operation.
    • Allow ventilator to run and make sure 'No battery capacity'- alarm is not activated.
    • Servo-i Service Manual 5-2.
  3. Siemens-Maquet Servo-i Battery Module Replacement: шаг 5, изображение 1 из 1
    • The time between the 'Limited battery capacity'- alarm and the 'No battery capacity' alarm must not exceed 7 minutes.
    • The event log contains the records of alarm times.
  4. Siemens-Maquet Servo-i Battery Module Replacement: шаг 6, изображение 1 из 3 Siemens-Maquet Servo-i Battery Module Replacement: шаг 6, изображение 2 из 3 Siemens-Maquet Servo-i Battery Module Replacement: шаг 6, изображение 3 из 3
    • See if the upper part of the module is equipped with a latch. This means it is fixed and follow these instructions to disassemble a battery from the battery module.
    • 1. Locate a small hexagonal wrench or screwdriver.
    • Place the tool in the small hole on the right hand side.
    • 2. Simultaneously push the release button.
    • 3. Remove the tool, while still pressing the release button.
    • 4. Continue to keep the button pressed until the battery pops out.
    • 5. Pull out the battery module.
    • Servo-i Service Manual 4-18.
Заключение
Monroe Erle
Участник с: 05/04/20
133 Репутация
1 руководство автора
Команда
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Участник Cal Poly, Team S1-G2, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G2
5 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 16
За всё время: 1,001
