Введение
The nozzles are part of the Maintenance Kit 5000 hours that should be done before hooking up to a patient. The prerequisite guide is the filter replacement for the gas module.
Preventive maintenance
Maintenance kit, 5,000 hours
Only original parts from the manufacturer must be used. Spare parts and maintenance kits can be ordered from your local Maquet representative. When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used. The following parts shall be replaced and they are included in the 'Maintenance kit, 5,000 hours':
A. Filters for the gas modules
B. Nozzle units for the gas modules
C. Bacteria filter for the inspiratory pressure transducer
D. Bacteria filter for the O2 cell
Performing the Preventive maintenance:
• Disassembling and assembling of the unit is required when replacing parts included in the 'Maintenance kit, 5,000 hours'. If not stated otherwise, refer to chapter 'Disassembling and assembling' for instructions.
• The letters A – D in the text below refers to the description of the Maintenance kit above.
• Prepare the unit as described in section 'Preparations' above in this chapter
Service Manual 7-3
Выберете то, что вам нужно
Remove the inspiratory section cover
Loosen the screw (1)
Lift off the gas module bracket (2)
Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
Replace plastic nozzle units in the gas modules.
Еще один человек закончил это руководство.
