Введение
If your car charger is no longer plugging in correctly, or if you have noticed that the metal sides of it are no longer in their correct shape, this guide can help you replace those metal side pieces, called: negative contacts. Negative Contacts in car phone chargers may get bent or stuck inside the device, making it difficult to plug back in.
If there is a possibility this is because your car charger got wet, you will need to proceed with caution, and wear gloves once you reach the circuit board.
Выберете то, что вам нужно
Remove the two 5 mm Phillips screws with a Phillips #1 screwdriver.
Remove the cover.
Gently pull apart the car charger case along the sides. This will reveal the circuit board.
Since everything has been glued or soldered onto the circuit board, you can gently remove the circuit board from the case by lifting it by the USB port's end.
Gently lift the negative contacts from the USB port.
Replace your negative contacts, or bend them back into their correct shape. Resembling a half oval shape as shown.
To begin reassembling the car charger first, lay the circuit board side into the bottom half of the car charger's case.
Make sure to align the light with its correct spot. It should be in the small, half-circle indent.
Gently place the negative contacts on top of the USB port.
The negative contacts are going to over-extend their correct slots, once you have the latch aligned on top of the USB port, carefully push in the sides of the contacts and lay them into their correct slots.
Now place the two halves of the car charger's case back together and close it tight.
To reassemble your device, go back to step 2 then step 1, and follow them in reverse order.
Еще один человек закончил это руководство.
