Sirius Stiletto 100 Volume Button Replacement
Выберете то, что вам нужно
  1. Sirius Stiletto 100 Volume Button Replacement, Front Cover: шаг 1, изображение 1 из 2 Sirius Stiletto 100 Volume Button Replacement, Front Cover: шаг 1, изображение 2 из 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Sirius Stiletto 100 Volume Button Replacement: шаг 2, изображение 1 из 2 Sirius Stiletto 100 Volume Button Replacement: шаг 2, изображение 2 из 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Sirius Stiletto 100 Volume Button Replacement: шаг 3, изображение 1 из 3 Sirius Stiletto 100 Volume Button Replacement: шаг 3, изображение 2 из 3 Sirius Stiletto 100 Volume Button Replacement: шаг 3, изображение 3 из 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Sirius Stiletto 100 Volume Button Replacement, Circuit Board: шаг 4, изображение 1 из 1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Sirius Stiletto 100 Volume Button Replacement: шаг 5, изображение 1 из 2 Sirius Stiletto 100 Volume Button Replacement: шаг 5, изображение 2 из 2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Sirius Stiletto 100 Volume Button Replacement: шаг 6, изображение 1 из 1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  7. Sirius Stiletto 100 Volume Button Replacement, Volume Button: шаг 7, изображение 1 из 1
    • Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
  8. Sirius Stiletto 100 Volume Button Replacement: шаг 8, изображение 1 из 1
    • Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
  9. Sirius Stiletto 100 Volume Button Replacement: шаг 9, изображение 1 из 1
    • Push on the volume button with both of your thumbs. Wiggle the volume button back and forth as you push upwards.
    • The volume button will pop out.
  10. Sirius Stiletto 100 Volume Button Replacement: шаг 10, изображение 1 из 1
    • Remove the volume button from the device.
  11. Sirius Stiletto 100 Volume Button Replacement: шаг 11, изображение 1 из 1
    • Slide the new volume button into the slot for the volume button.
    • Make sure that the volume button is oriented correctly. An easy way to check this is to hold the volume button in place and look at the side of the device.
  12. Sirius Stiletto 100 Volume Button Replacement: шаг 12, изображение 1 из 1
    • Push down on the volume button to snap it back into the case.
Заключение
Еще один человек закончил это руководство.
Morgan McDougald
Участник с: 03/09/12
71 Репутация
Автор 3 руководств
Команда
Clemson, Team 2-1, Benson Spring 2012 Участник Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 членов
Автор 6 руководств
Один комментарий
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
Rich Ridout - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,317
