Skateboard Wheel Replacement
Выберете то, что вам нужно
  1. Skateboard Wheel Replacement, The skate board fix up: шаг 1, изображение 1 из 1
    • With a 13mm wrench, remove the axle nut located in the center of the wheel.
    • Set the axle nut aside, and remove the wheel.
  2. Skateboard Wheel Replacement, Remove the Bearings: шаг 2, изображение 1 из 1
    • Position the wheel at the end of the axle.
    • To remove the bearings, gently pry the wheel at a downward angle.
    • Perform this prying process on both sides of the wheel.
    • A bearing spacer should fall out once the bearings are removed.
  3. Skateboard Wheel Replacement: шаг 3, изображение 1 из 1
    • Position the new wheel on a flat surface.
    • Press the bearing into the hole of the new wheel.
    • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
  4. Skateboard Wheel Replacement: шаг 4, изображение 1 из 1
    • Flip the wheel over.
    • Insert the bearing spacer into the back the wheel.
  5. Skateboard Wheel Replacement: шаг 5, изображение 1 из 1
    • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
    • With the bearings in place, the wheel can be placed on the axle.
  6. Skateboard Wheel Replacement: шаг 6, изображение 1 из 1
    • Slide one washer onto the axle.
  7. Skateboard Wheel Replacement: шаг 7, изображение 1 из 1
    • Slide the wheel onto the axle.
    • The axle should go through both bearings and the bearing spacer.
  8. Skateboard Wheel Replacement: шаг 8, изображение 1 из 1
    • Slide the second washer onto the axle on the outside of the wheel.
  9. Skateboard Wheel Replacement: шаг 9, изображение 1 из 1
    • Tighten the axle nut firmly.
    • Do not over tighten. The wheel should spin freely.
    • Repeat steps 1-9 for the remaining wheels.
Заключение
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
9 участников успешно повторили данное руководство.
Jared Stine
Участник с: 10/05/12
800 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 6-32, Regan Fall 2012 Участник Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 членов
Автор 6 руководств
3 Комментариев
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - Ответить
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - Ответить
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 14
За последние 30 дней: 67
За всё время: 78,251
