Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement
Выберете то, что вам нужно
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Un-clip Battery: шаг 1, изображение 1 из 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove Battery: шаг 2, изображение 1 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove Battery: шаг 2, изображение 2 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove Battery: шаг 2, изображение 3 из 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove Handle: шаг 3, изображение 1 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove Handle: шаг 3, изображение 2 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove Handle: шаг 3, изображение 3 из 3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  4. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the screw from the chuck sleeve: шаг 4, изображение 1 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the screw from the chuck sleeve: шаг 4, изображение 2 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the screw from the chuck sleeve: шаг 4, изображение 3 из 3
    • The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
  5. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the chuck sleeve: шаг 5, изображение 1 из 2 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the chuck sleeve: шаг 5, изображение 2 из 2
    • The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
  6. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the screws from the adjustable clutch: шаг 6, изображение 1 из 2 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the screws from the adjustable clutch: шаг 6, изображение 2 из 2
    • Set the adjustable clutch to the "1" setting before beginning. This will make it easier to remove.
    • The adjustable clutch is held on by 2 20mm T10 Torx screws. Insert a T10 Torx screwdriver and rotate it counterclockwise to loosen and remove each screw.
  7. Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the adjustable clutch: шаг 7, изображение 1 из 2 Skil X-Drive 18V Cordless Drill Model No. 2887 Adjustable Clutch Replacement, Remove the adjustable clutch: шаг 7, изображение 2 из 2
    • Firmly grip the outside of the adjustable clutch and pull it off.
    • There is a metal washer behind the adjustable clutch that holds in 12 small ball bearings. Hold the drill so it is pointing up slightly so the washer and bearings do not fall out.
Заключение
Еще один человек закончил это руководство.
Jameson
Участник с: 09/23/14
258 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-3, Blackwell Fall 2014 Участник USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 членов
Автор 9 руководств
Один комментарий
Jameson,
Beautifully done. I have a question. The phillips head screw is all screwed up there isn’t any way I can loosen it. If I could put of of those screw looseners on it that you hit with a hammer to break the screw loose that would probably work but the chuck doesn’t open enough to do that. Besides dynamite or a band saw do you know of any other way to get the cover off so I can get some other tools on that screw? Speaking of a band saw can I cut off the black plastic cover on the chuck and will that allow me to get to that screw? Before you ask yes I heard you the screw is a left hand thread.l Thank you.
RTFavara (Richard)
Richard Favara - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 20
За всё время: 1,006
