Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
Выберете то, что вам нужно
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: шаг 1, изображение 1 из 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: шаг 2, изображение 1 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: шаг 2, изображение 2 из 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: шаг 2, изображение 3 из 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Заключение
4 участников успешно повторили данное руководство.
Sean
Участник с: 09/23/14
282 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 2-3, Blackwell Fall 2014 Участник USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 членов
Автор 9 руководств
5 Комментариев
my battery is stuck in the drill any ideas
yonko99 - Ответить
My battery is also stuck. I see no replies. What now?
Bobby Verdier - Ответить
Thank you, it really was easy !!!!!
Betty - Ответить
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - Ответить
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 21
За последние 30 дней: 72
За всё время: 6,114
