SkullCandy Hesh Auxiliary Cable Replacement
Выберете то, что вам нужно
  1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: шаг 1, изображение 1 из 1
    • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
  2. SkullCandy Hesh Auxiliary Cable Replacement: шаг 2, изображение 1 из 1
    • Using wire cutters, cut the auxiliary cable at the determined damaged area.
    • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
  3. SkullCandy Hesh Auxiliary Cable Replacement: шаг 3, изображение 1 из 2 SkullCandy Hesh Auxiliary Cable Replacement: шаг 3, изображение 2 из 2
    • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
  4. SkullCandy Hesh Auxiliary Cable Replacement: шаг 4, изображение 1 из 1
    • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
    • Twist together the same colored wires from the device cable and the new cable.
  5. SkullCandy Hesh Auxiliary Cable Replacement: шаг 5, изображение 1 из 1
    • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
  6. SkullCandy Hesh Auxiliary Cable Replacement: шаг 6, изображение 1 из 1
    • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
Заключение
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
Sarah Burk
Участник с: 01/15/15
247 Репутация
Автор 3 руководств
Команда
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Участник USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 членов
Автор 10 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 1,207
