Skullcandy Air Raid Buttons Replacement
Выберете то, что вам нужно
  1. Skullcandy Air Raid Buttons Replacement, Rubber Cover: шаг 1, изображение 1 из 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Buttons Replacement, Handle: шаг 2, изображение 1 из 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Buttons Replacement, Front Plate: шаг 3, изображение 1 из 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Buttons Replacement: шаг 4, изображение 1 из 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Buttons Replacement, Control Buttons: шаг 5, изображение 1 из 2 Skullcandy Air Raid Buttons Replacement, Control Buttons: шаг 5, изображение 2 из 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
    • Lift the button panel.
  6. Skullcandy Air Raid Buttons Replacement, Button Motherboard: шаг 6, изображение 1 из 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  7. Skullcandy Air Raid Buttons Replacement: шаг 7, изображение 1 из 1
    • Using a plastic opening tool, pry up on the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  8. Skullcandy Air Raid Buttons Replacement, Ribbon Cable: шаг 8, изображение 1 из 1
    • First, pull on the black attachment to disconnect it from the metal piece.
    • Release the cable from the back of the motherboard.
    • The black attachment is a part of the connector, not the blue ribbon cable. It will not disconnect from the motherboard.
Заключение
2 участников успешно повторили данное руководство.
Sasha Nevin
Участник с: 01/13/15
257 Репутация
1 руководство автора
Команда
Eastern Washington University, Team 1-3, Carnegie Winter 2015 Участник Eastern Washington University, Team 1-3, Carnegie Winter 2015
EWU-CARNEGIE-W15S1G3
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,280
