Выберете то, что вам нужно
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Gently pull the sides of the front plate outwards from the device.
Pull up on the front plate to remove it from the device.
Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
Using a plastic opening tool, pry the button motherboard to detach it from the device.
Pull the black ribbon cord attachment away from the motherboard.
Pull on the cable until it releases from the back of the motherboard.
Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
Lift off the back panel.
Pull the black piece of the USB port ribbon cable connector away from the motherboard.
Pull the ribbon cable out of the connector.
Pull the USB power cable away from the motherboard to disconnect it.
Pull the battery power cable away from the motherboard to disconnect it.
