Skullcandy Air Raid Motherboard Replacement
Выберете то, что вам нужно
  1. Skullcandy Air Raid Motherboard Replacement, Rubber Cover: шаг 1, изображение 1 из 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Motherboard Replacement, Handle: шаг 2, изображение 1 из 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Motherboard Replacement, Front Plate: шаг 3, изображение 1 из 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Motherboard Replacement: шаг 4, изображение 1 из 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Motherboard Replacement, Speakers: шаг 5, изображение 1 из 1
    • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
  6. Skullcandy Air Raid Motherboard Replacement: шаг 6, изображение 1 из 1
    • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Motherboard Replacement: шаг 7, изображение 1 из 1
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Motherboard Replacement: шаг 8, изображение 1 из 1
    • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Motherboard Replacement, Control Buttons: шаг 9, изображение 1 из 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
  10. Skullcandy Air Raid Motherboard Replacement: шаг 10, изображение 1 из 1
    • Lift the button panel.
  11. Skullcandy Air Raid Motherboard Replacement, Button Motherboard: шаг 11, изображение 1 из 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  12. Skullcandy Air Raid Motherboard Replacement: шаг 12, изображение 1 из 1
    • Using a plastic opening tool, pry the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  13. Skullcandy Air Raid Motherboard Replacement, Ribbon Cable: шаг 13, изображение 1 из 1
    • Pull the black ribbon cord attachment away from the motherboard.
    • Pull on the cable until it releases from the back of the motherboard.
    • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
  14. Skullcandy Air Raid Motherboard Replacement, Back panel: шаг 14, изображение 1 из 2 Skullcandy Air Raid Motherboard Replacement, Back panel: шаг 14, изображение 2 из 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
    • Lift off the back panel.
  15. Skullcandy Air Raid Motherboard Replacement, Battery and USB Port Cables: шаг 15, изображение 1 из 1
    • Pull the black piece of the USB port ribbon cable connector away from the motherboard.
    • Pull the ribbon cable out of the connector.
  16. Skullcandy Air Raid Motherboard Replacement: шаг 16, изображение 1 из 1
    • Pull the USB power cable away from the motherboard to disconnect it.
    • Pull the battery power cable away from the motherboard to disconnect it.
  17. Skullcandy Air Raid Motherboard Replacement, Motherboard: шаг 17, изображение 1 из 1
    • Pull up on the motherboard from both sides.
Заключение
Timothy Potts
Участник с: 01/13/15
201 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 1-3, Carnegie Winter 2015 Участник Eastern Washington University, Team 1-3, Carnegie Winter 2015
EWU-CARNEGIE-W15S1G3
3 членов
Автор 6 руководств
Один комментарий
I need a new motherboard. Front and rear. Can I order one?
Nick Fines - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 1,616
