Skullcandy Air Raid Speakers Replacement
Выберете то, что вам нужно
  1. Skullcandy Air Raid Speakers Replacement, Rubber Cover: шаг 1, изображение 1 из 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Speakers Replacement, Handle: шаг 2, изображение 1 из 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Speakers Replacement, Front Plate: шаг 3, изображение 1 из 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Speakers Replacement: шаг 4, изображение 1 из 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Speakers Replacement, Speakers: шаг 5, изображение 1 из 1
    • Using a #000 Phillips Screwdriver, unscrew the four 0.8 cm Philips screws from each corner of the speaker you are replacing (eight 0.8 Philips screws total).
  6. Skullcandy Air Raid Speakers Replacement: шаг 6, изображение 1 из 1
    • Using the plastic opening tool, pry around edges of speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Speakers Replacement: шаг 7, изображение 1 из 1
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Speakers Replacement: шаг 8, изображение 1 из 1
    • Firmly pull on the end of the ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Speakers Replacement, Desolder Wires: шаг 9, изображение 1 из 1
    • Desolder the black and red wires from the speaker.
    • The red wire is for the left speaker and the black is for the right speaker.
Заключение
2 участников успешно повторили данное руководство.
Kristin
Участник с: 01/13/15
495 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team 1-3, Carnegie Winter 2015 Участник Eastern Washington University, Team 1-3, Carnegie Winter 2015
EWU-CARNEGIE-W15S1G3
3 членов
Автор 6 руководств
Один комментарий
Where can I buy the replacement speaker?
Luis Polino - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 1,578
