Skullcandy Mix Master DJ Mylar Driver Replacement
Выберете то, что вам нужно
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: шаг 1, изображение 1 из 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: шаг 1, изображение 2 из 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: шаг 1, изображение 3 из 3
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 2, изображение 1 из 1
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 3, изображение 1 из 2 Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 3, изображение 2 из 2
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 4, изображение 1 из 2 Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 4, изображение 2 из 2
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 5, изображение 1 из 2 Skullcandy Mix Master DJ Mylar Driver Replacement: шаг 5, изображение 2 из 2
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
Заключение
Еще один человек закончил это руководство.
Sean Herlihy
Участник с: 03/30/15
117 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 1-3, Shastany Spring 2015 Участник UMass Dartmouth, Team 1-3, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G3
3 членов
Автор 3 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,633
