Введение
The wires in headphones are an essential part. If sound is not generating from one speaker, the problem may be from a rip or break in the wires found within the earpiece. This guide shows you how to repair a broken wire inside the earpiece for the Skullcandy UPROCK S5URFZ-390.
Выберете то, что вам нужно
If a wire is broken, use a soldering iron to reattach it to the speaker.
To learn how to solder, read the How To Solder and Desolder Connections Guide.
After soldering is complete, the wires should look like this.
2 участников успешно повторили данное руководство.
Один комментарий
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
