Введение
If the device is having poor battery performance, consider replacing the battery of the Sky 6.0Q phone. The battery of the device only has a set performance life, and is more cost effective to replace that purchasing a completely new phone. The design of the Sky 6.0Q phone makes accessing the battery difficult, so it is necessary to be careful when removing the back plates and to not lose the small screws. It is recommended to use a magnetic work board to keep the screws from rolling away and are always on hand once the battery is replaced. Also, the battery itself is thin, so make sure to not tear or puncture it during removal. Lithium is toxic, so leaking of this on the phone or user can be dangerous.
Выберете то, что вам нужно
Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
Pry off the back plate with the spudger.
After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
Use the plastic opening tool to help pry up the plastic backing.
Once loose, remove the plastic backing to expose underlying electronic components.
Disconnect the gold cord extending from the battery to the top electronic board.
Use the nylon spudger to help pry up the battery attachment.
Use the nylon spudger to get underneath the battery and separate it from the phone back.
2 участников успешно повторили данное руководство.
