1. You will need: CR 2032 Battery Philips #0 screwdriver
    • You will need:
      • CR 2032 Battery
      • Philips #0 screwdriver
      • Something to pop the battery out, like a thin spudger, or a #2 slot screwdriver.
  2. Remove these four screws. They're all the same size. Remove these four screws. They're all the same size.
    • Remove these four screws. They're all the same size.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Lift off the case back. Underneath, you'll see a sheet of plastic film. It should be possible to remove the battery without removing the film, if you're careful, but I didn't want to risk bending or tearing the plastic.
    • Lift off the case back.
    • Underneath, you'll see a sheet of plastic film. It should be possible to remove the battery without removing the film, if you're careful, but I didn't want to risk bending or tearing the plastic.
    • If you do take the plastic off, beware of maneuvering it over the three springs in the upper left, and the small prong that sticks out over the battery. You'll need to be sure to arrange the plastic carefully over these obstructions when re-assembling.
  5. Insert spudger or flat screwdriver in the notch indicated by the arrow, and lever out the battery.
    • Insert spudger or flat screwdriver in the notch indicated by the arrow, and lever out the battery.
    • The new battery should insert the same way the old one came out, and snap into place.
Заключение
Mark Boszko
Участник с: 02.02.2012
131 Репутация
1 Guide authored
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 8
За всё время: 803
