Выберете то, что вам нужно
Remove the sticker on the back of the Slingbox that covers the rear screws using a spudger.
Remove the seven 7.9 mm rear screws from the device using a Phillips #1 screwdriver.
Flip your Slingbox so the bottom is facing upwards.
Remove the four 7.9 mm screws using a Phillips #1 screwdriver.
Remove the upper section of the case by rotating your Slingbox to view the back and lifting up on the higher corner.
Use the opening tool to disconnect the small clips in the front.
Remove the entire top of the Slingbox and set it aside.
