Smartab STJR700 Back Camera Lens Replacement
Выберете то, что вам нужно
  1. Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: шаг 1, изображение 1 из 2 Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: шаг 1, изображение 2 из 2
    • First, use a screwdriver to remove the screws on the back cover of the Smartab.
    • Next, carefully remove the cover to reveal the inside of the tablet.
  2. Smartab STJR700 Back Camera Lens Replacement: шаг 2, изображение 1 из 3 Smartab STJR700 Back Camera Lens Replacement: шаг 2, изображение 2 из 3 Smartab STJR700 Back Camera Lens Replacement: шаг 2, изображение 3 из 3
    • When you open the tablet, you will see several components.
    • You will see that the camera is stabilized by screws. The digitizer is held in place using black tape.
    • When the black tape is peeled back, you will see that the digitizer is also connected to the motherboard.
  3. Smartab STJR700 Back Camera Lens Replacement: шаг 3, изображение 1 из 3 Smartab STJR700 Back Camera Lens Replacement: шаг 3, изображение 2 из 3 Smartab STJR700 Back Camera Lens Replacement: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a screwdriver to unscrew the camera from the tablet.
    • Use tweezers to remove the digitizer from the hard drive.
    • After the digitizer is removed and the camera is unscrewed, remove them from the tablet.
    • Replace the old camera with a replacement camera by using a screwdriver. Replace the old digitizer with a replacement digitizer by using a soldering tool.
    • To replace the camera lens, start by removing the broken glass by using tweezers.
    • If the new lens has adhesive, make sure that all the old adhesive is removed from the frame so that the lens does not stick out, and so a tighter seal is formed.
    • Once the glass is removed, place the new camera lense by peeling off the upper film and align the glass with the ring.
Заключение
Fatu Woodson
Участник с: 03/08/17
101 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 Участник UMass Dartmouth, Team S3-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G4
4 членов
Автор 5 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 456
