Введение
This repair guide should only be used if all other options have been exhausted and the tablet's home button is still unresponsive. Before attempting to replace the home button, make sure the unresponsive home button is not experiencing a software issue.
Выберете то, что вам нужно
Power off device. Place it face down. Unscrew the four perimeter screws using a PH000.
Using a plastic opening tool or metal spudger, begin to gently pry the rear case down and away from the display. Slowly wiggle the tool up and down to pry open the tablet. Once the rear case is fully removed, place it to the side.
Remove the two Phillips #000 screws holding the home button board to the front panel.
Using tweezers, slowly and carefully remove the end of the cable that connects the home button to the main motherboard.
To ensure a successful replacement make sure to follow all steps carefully .
