Выберете то, что вам нужно
There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
Remove the bottom or back of the device by detaching the black bottom after removing the screws.
the front panel should now be exposing the digitizer along with the other electronic components of the device.
Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
Еще один человек закончил это руководство.
