Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Snowboard bindings are easy to take apart and replace. In this guide we will show you how to replace a Union Force binding. Most snowboard bindings are very similar to remove, but there may be some slight differences.
Выберете то, что вам нужно
Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
Lift or slide the binding off the board and set the screws aside.
2 участников успешно повторили данное руководство.
