Sol Republic Deck LED Lights Replacement
Выберете то, что вам нужно
  1. Sol Republic Deck LED Lights Replacement, LED Lights: шаг 1, изображение 1 из 2 Sol Republic Deck LED Lights Replacement, LED Lights: шаг 1, изображение 2 из 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Insert the tip of a plastic opening tool or spudger into the the middle groove along the edge of the device.
    • Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck LED Lights Replacement: шаг 2, изображение 1 из 2 Sol Republic Deck LED Lights Replacement: шаг 2, изображение 2 из 2
    • Using a PH00 screwbit, unscrew the two three-tenth cm screws and remove them.
    • Once the screws have been removed, lift the SOL plate revealing the LED Light strip.
  3. Sol Republic Deck LED Lights Replacement: шаг 3, изображение 1 из 1
    • Using a PH00 screwbit, unscrew the two three-tenth screws that hold down the LED light strip at both ends.
  4. Sol Republic Deck LED Lights Replacement: шаг 4, изображение 1 из 1
    • Using a PH00 screw bit, unscrew the three screws that hold down the motherboard.
  5. Sol Republic Deck LED Lights Replacement: шаг 5, изображение 1 из 1
    • Use tweezers and fingers to lift tab and ZIF (zero insertion force) connecter.
  6. Sol Republic Deck LED Lights Replacement: шаг 6, изображение 1 из 1
    • Once unscrewed, the LED light requiring repair can be accessed by lifting up the entire LED light strip with tweezers.
  7. Sol Republic Deck LED Lights Replacement: шаг 7, изображение 1 из 1
    • If you pull the LED light plate too hard, then the motherboard will snap in half.
    • Lift the LED light plate attached to the motherboard off.
Заключение
4 участников успешно повторили данное руководство.
Kristina Patel
Участник с: 09/24/15
137 Репутация
1 руководство автора
Команда
University of Alabama, Team 1-1, Sydow campbell Fall 2015 Участник University of Alabama, Team 1-1, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G1
5 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 2,080
