Введение
There is a play/pause button with an "M" on it located on the front cover of the speaker beneath the letters SOL. This button controls the starting and stopping of the music.
Выберете то, что вам нужно
Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
Еще один человек закончил это руководство.
