Sol Republic Deck Volume Buttons Replacement
Выберете то, что вам нужно
  1. Sol Republic Deck Volume Buttons Replacement, Volume Buttons: шаг 1, изображение 1 из 2 Sol Republic Deck Volume Buttons Replacement, Volume Buttons: шаг 1, изображение 2 из 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • To separate the front face plate from the bottom half of the speaker, insert a spudger into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck Volume Buttons Replacement: шаг 2, изображение 1 из 2 Sol Republic Deck Volume Buttons Replacement: шаг 2, изображение 2 из 2
    • Locate the black plastic volume buttons on each side of the back of the speaker face.
    • A piece of black tape on the side panel may also be covering the yellow connector tip that holds the volume button in place. Remove the black tape if necessary.
  3. Sol Republic Deck Volume Buttons Replacement: шаг 3, изображение 1 из 1
    • Using the plastic spudger, pry the button from the front plate of the speaker. The volume button is connected to the speaker by a plastic tab that has blue glue holding it down. The entire volume button can be removed from the front plate by carefully using the spudger to lift it up until it comes off.
Заключение
2 участников успешно повторили данное руководство.
Rebekah Simmons
Участник с: 09/24/15
221 Репутация
1 руководство автора
Команда
University of Alabama, Team 1-1, Sydow campbell Fall 2015 Участник University of Alabama, Team 1-1, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G1
5 членов
Автор 3 руководств
3 Комментариев
No problem! Glad you were able to fix your speaker :)
Shelby Ray -
So I dropped my speaker from 2 ft and the volume up doesn't work even after opening it up and trying to replace it. Is there any thing I may have missed?
nick ed - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 14
За всё время: 1,218
