Введение
A batteries' cycle life will only last for so many charges. In time the battery may no longer hold a charge to power your device. In this guide, we will show you how to change the battery of the Solio Rocsta.
Выберете то, что вам нужно
Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
With the circuit board flipped, locate the battery connector.
Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
Еще один человек закончил это руководство.
