Введение
This guide shows you how to remove the battery and motherboard from the body of the Solio Rocsta.
Выберете то, что вам нужно
Insert the flat end of the spudger between the top panel and the body.
Use the spudger as a lever to carefully pry apart the two panels.
Lift the panel above and away to disconnect the panel from the body.
Еще один человек закончил это руководство.
