Введение
If the screen on the Sonos Play 1 is dented, cracked or damaged, it may interfere with audio performance and may cause damage to the speakers. In order to prevent damage to the speakers and increase the devices performance, the exterior screen protecting the internal housing of the speakers will need to be replaced. This guide will demonstrate this process of removing the screen.
Выберете то, что вам нужно
Using a metal spudger, pry open a corner of the adhesive tape.
Use precision tweezers to remove the adhesive tape.
Remove the four 10 mm Torx security #10 screws that hold the base together.
Remove the base by lifting it vertically away from the bulk of the device.
Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
Using precision tweezers, remove the metal bracket.
12 участников успешно повторили данное руководство.
6 Комментариев
Where can you purchase a replacement screen please? I dented mine by accident.
where to buy the replacement screen?
