Sonos Play 5 Motherboard Replacement
Выберете то, что вам нужно
  1. Sonos Play 5 Motherboard Replacement, Front Panel Assembly: шаг 1, изображение 1 из 1
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Motherboard Replacement: шаг 2, изображение 1 из 2 Sonos Play 5 Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Motherboard Replacement: шаг 3, изображение 1 из 3 Sonos Play 5 Motherboard Replacement: шаг 3, изображение 2 из 3 Sonos Play 5 Motherboard Replacement: шаг 3, изображение 3 из 3
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Motherboard Replacement: шаг 5, изображение 1 из 2 Sonos Play 5 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Motherboard Replacement: шаг 6, изображение 1 из 3 Sonos Play 5 Motherboard Replacement: шаг 6, изображение 2 из 3 Sonos Play 5 Motherboard Replacement: шаг 6, изображение 3 из 3
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Motherboard Replacement, Motherboard: шаг 7, изображение 1 из 3 Sonos Play 5 Motherboard Replacement, Motherboard: шаг 7, изображение 2 из 3 Sonos Play 5 Motherboard Replacement, Motherboard: шаг 7, изображение 3 из 3
    • Remove the ten pin connector.
  8. Sonos Play 5 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Flip the device over on its front side.
  9. Sonos Play 5 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Remove six 5mm Phillips #0 screws.
    • Remove two 7mm Phillips #2 screws.
  10. Sonos Play 5 Motherboard Replacement: шаг 10, изображение 1 из 1
    • Flip the device on its back.
  11. Sonos Play 5 Motherboard Replacement: шаг 11, изображение 1 из 3 Sonos Play 5 Motherboard Replacement: шаг 11, изображение 2 из 3 Sonos Play 5 Motherboard Replacement: шаг 11, изображение 3 из 3
    • Remove the grey and red antenna connectors by lifting them away from the board.
    • Pull cords away from the board.
  12. Sonos Play 5 Motherboard Replacement: шаг 12, изображение 1 из 2 Sonos Play 5 Motherboard Replacement: шаг 12, изображение 2 из 2
    • Remove the yellow antenna connector by lifting it away from the board.
    • Pull cord away from the board.
  13. Sonos Play 5 Motherboard Replacement: шаг 13, изображение 1 из 3 Sonos Play 5 Motherboard Replacement: шаг 13, изображение 2 из 3 Sonos Play 5 Motherboard Replacement: шаг 13, изображение 3 из 3
    • Remove circuit board by lifting it straight away from the rear plate.
Заключение
8 участников успешно повторили данное руководство.
Khari Barley
Участник с: 02/20/17
203 Репутация
1 руководство автора
Команда
USF Tampa, Team S3-G6, Sullivan Spring 2017 Участник USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
4 членов
Автор 16 руководств
3 Комментариев
So far so good, where to get a new power board?
Sonos P/N: 170-00236
B. Buil - Ответить
Where do you get the parts?
bodtker - Ответить
Possible to buy components anywhere?
thomaspmunster - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 18
За последние 30 дней: 73
За всё время: 8,284
